It is currently Tue Aug 12, 2025 2:48 pm
 Post subject: Top wood hardness
PostPosted: Mon Dec 28, 2015 11:33 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm looking for recommendations for top wood that has good hardness. Mostly have used Lutz, and I love the look and sound. But it is soft. Maybe all spruces are soft?
 Post subject: Re: Top wood hardness
PostPosted: Tue Dec 29, 2015 1:17 am
Why do you want a hard top?
PostPosted: Tue Dec 29, 2015 1:29 am
Last Name: Kincheloe
This.
As far as surface hardness goes, I'd say Honduran rosewood is the hardest that could likely function well as a top... but it will be super thin and brittle. Purpleheart would be a little thicker (probably .070" or so), and better stiffness to weight ratio too, but still pretty brittle. Black walnut is probably the toughest all around, plus it will work with traditional bracing styles. And of course koa is popular.
As far as softwoods go, perhaps Douglas-fir? Or just particularly hard samples of any spruce. Red is the hardest/heaviest on average, but they all vary a lot from piece to piece.
PostPosted: Tue Dec 29, 2015 5:23 am
Adirondack spruce is the hardest spruce I've worked with or even seen.
I got some from the hampton bros couple of months ago, baked it (because it's been logged recently) and it's seriously hard.
Even an accidentally sprung go-bar hardly marked it.
Well cut and rings like a bell.
PostPosted: Tue Dec 29, 2015 8:09 am
First name: Fred
City: Winnipeg
PostPosted: Tue Dec 29, 2015 11:30 am
First name: Greg
Last Name: B
City: Los Angeles
Sitka spruce. I don't care what anyone says, it has a beautiful sound if well utilized.
You can always go to a mahogany top, but the sound is different.
PostPosted: Tue Dec 29, 2015 1:07 pm
" Maybe all spruces are soft?"
Yes, more or less: do you suppose that has some bearing on why they're called 'softwoods'? :)
Actually, Doug fir can have surface hardness that's close to that of oak, which is why they use it for flooring. Much of the Doug that I've seen has very heavy latewood lines, which is where the hardness comes from. It's not difficult to find similar looking spruce or redwood. The down side there is that such wood tends to be dense, and have rather low long-grain stiffness relative to it's density, so it makes a heavy top. That's OK if you're looking for something that has lots of 'headroom' and don't need 'responsiveness'. Without knowing why you want a hard top it's difficult to know what to tell you.
PostPosted: Tue Dec 29, 2015 3:20 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Zip/Postal Code: 99921
Country: USofA
[quote="Greg B"]Sitka spruce. I don't care what anyone says, it has a beautiful sound if well utilized.
thanks Greg for your confidence in Sitka. It is a dandy choice. Pretty soon it will be extremely rare to get any old growth of that specie.
I can fix you up with some Sitka that will blow your socks off. Order a 3a set from my online store at alaskawoods.com and put in the comments box you are looking for hardness. I was grading some of my light curly sets yesterday. Have some real dandies from 2 differant logs. Both blow downs. One purchased in 2006 ish from a sale I had at Labachure Bay, and the other from another salvage just down the road here in Port St Nick. And of coarse Stiff as glass too? Talk about ring like a bell! 3A light curly. There is also some 2a ff BearClaw that is harder than most too. By the way, this would not be hard because of "hard Grain" or Compression wood. Just good clean heartwood.
PostPosted: Wed Dec 30, 2015 12:13 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Brent, I know I've playing message tag with you. I am looking for some claw. Just that I've been so busy finishing up a few guitars. As for top wood hardness, I was just wondering if there was a notable grading amongst the various spruce species. Or does it matter more where the wood came from in the tree (heart wood?).
PostPosted: Wed Dec 30, 2015 12:47 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Country: USofA
Every tree is different. The trees I dissect average 400 years old. Each has it's history recorded in its growth rings. Many factors contribute to color, texture and form. There is certainly a common density, and then there are those rare birds, like some of this very hard and the ultra-light that we have some of. Generally speaking though, the denser fiber will come from the butt of a tree. In these 150-220' trees, that would be the first 10' or so. Heartwood, is pretty much all wood fiber inside the cambium layer[sapwood],carrying the water, just under the bark.
I have some harder bearclaw in the 2AFF and the 3A-FF sorts.
